Old 05-12-2017, 01:31 PM
1574trap 1574trap is offline
Default 2182 cub cadet
the idiot light is coming on my gen. system when a load is placed on it -- lights and/or mower deck clutch. it will go out if engine speed is run 3000 rpm or more ect. the lights seem to be a lesser elect load than the mower deck clutch. can I assume my alternator is going bad? do not know if this alternator has an internal voltage regulator. can have the alternator tested at autozone -- I think. looking for advise on this issue.
Old 05-12-2017, 02:17 PM
Terry C's Avatar
Terry C Terry C is offline
AutoZone will be no help. No internal regulator. You can check everything yourself with a voltmeter. If your interested in our help in doing it yourself, begin by finding the regulator. It's on the left side of the battery tray. It's a aluminum finned box with wires coming out. Let's start there.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-12-2017, 02:47 PM
Take the bulb out of the idiot light and forget about it.
Old 05-12-2017, 03:33 PM
If you're mowing the engine should be well over 3,000rpm anyway so I'm not sure what the issue is.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-12-2017, 10:49 PM
the local auto-zone has a test stand to check alternators -- if it has not disappeared. my assumption is an alternator should charge at idle engine speed. will do a little checking with a volt meter and see what turns up.
Old 05-12-2017, 11:13 PM
RLause's Avatar
RLause RLause is offline
Get a manual for the tractor and the one for the engine. Most of the troubleshooting will be covered.
Richard
Old 05-12-2017, 11:44 PM
Guys, the cyclops tractors are known for this issue. It isn't real. The light has a tendency to be on because of how the system is wired. Just test battery voltage with a meter with the engine running. Should have around 14 volts at WOT, and around 13 at idle. If you do, it's fine. Don't go pulling parts off and running them around. Just take 30 seconds next time you use the tractor and check it. You'll likely find everything to be working fine. Then, do as Sam said and pull the bulb out.
Old 05-13-2017, 12:00 AM
CNeubauer CNeubauer is offline
My 2182 goes through periods where the volt light comes on and then it might go a couple months without coming on at all but the battery always stays charged.
Old 05-13-2017, 12:09 AM
Case in point.
Old 05-13-2017, 08:54 AM
sorner's Avatar
sorner sorner is offline
I've seen this with my 1641 and 1864. False alarm for me also.
