Old 07-13-2013, 03:46 PM
brad.bristle99's Avatar
brad.bristle99 brad.bristle99 is offline
Default Spark Plugs?
What is the best spark plug to run in my stock 100 puller. I have heard about all the new spark plugs being better, is it true?
Old 07-13-2013, 05:18 PM
austin8214's Avatar
Autolite 216
Old 07-13-2013, 07:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
on a stock motor I've not seen any gains on a dyno with spark plugs or coils for that matter. 6.5:1 compression flat head on gas. anything that lights the fire at the correct time seams to work.
Old 07-16-2013, 11:27 PM
If I bore the engine out and get an aluminum head would it change anything with the plugs or not?
Old 07-17-2013, 05:52 PM
dvogtvpe's Avatar
with a billet head its about location and using the flame travel. how much bore are you talking and what for fuel?
Old 07-17-2013, 10:31 PM
not sure on the bore yet and just regular gas that you get from a gas station. what kind of gas would be better to run?
Old 07-18-2013, 10:18 PM
dvogtvpe's Avatar
that would depend on what parts your going to use. cam, bore, head design, carb, valve size, ports. you're kind of building backwards.
Here's the first 10 questions you need to answer. spark plug heat range would probably be one of the last questions you need answered.
1 - read your rules
2 - decide if you still want to mow
3 - what can I afford
4 - can my drive line take it
5 - can I afford to beef that up
6 - what size tire's do I need
7 - will I need to regear
8 - can I afford that
9 - how much do I have left for a motor
10- mmm
