Kohler k321 with k361 rebuild kit
I have a 149 and the motor is starting to get tired and I was thinking about rebuilding it. I was wondering if I got a rebuild kit for a k341 wich is 16hp and came out of a 169. Would it work and would I have 16hp or not? Has any body done this??
Well, the biggest difference between the 2 rebuild kits is the diameter of the piston and the piston rings. So if you bored out your K321 (3.500" bore) out to 3.750", then yes, technically you would have a 16 hp engine. However I don't think you will have enough cylinder wall thickness left over to make it viable. I believe the only difference between the 149 and a 169 is the engine.
128 X 2, 129, 149, 1450 x 2 |
Thanks. I looked up the specs after I posted that and it's only the bore that's diffrent. I'll have to do some measuring to see how much wall thickness I'd have.
The K321 has 9 head bolts and the K361 has 10 head bolts. You will need a head gasket if you do this.
I agree with Green407.....You may leave the cylinder wall too thin and trash a block. The casting is different.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
