Old 06-18-2023, 02:45 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 1862 oil sensor
My new to me 1862 has the oil light staying on. It does not flicker. Have been using tractor and every thing sounds OK. Have changed the oil and filter and oil level staying on full. Does this mean the oil sensor is bad? Will I lose any oil out the sensor hole if I change the sensor? Thanks in advance for your help and have a great day.
Bob
Old 06-18-2023, 03:45 PM
Inactive Member
Possibly. The Oil Pressure Sensor is designed to come on with a pressure of less than 3.5 PSIG. With 3.6 and above, the light should go out. The circuit is designed to close the Pressure Switch, completing a path to ground. Thus, the possibility exists, that this wire (Green ???) could be shorted to ground. A meter (DVM) could determine this.
NO
Old 06-18-2023, 08:11 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Not knowing anything about a 1862 , I can tell you that the oil light stays on for 5 running hours each time the oil is required to be changed in my Kohler V-twin 22hp
I posted a thread on here about this , it is programmed in to the meter , I am not saying this applies to your mower but check it out
Here is the thread
https://www.onlycubcadets.net/forum/...ad.php?t=60543
Oz
Old 06-19-2023, 07:59 AM
Oak Oak is online now
Your 1862 should have a Kohler Mag 18 engine. I would not run this until you find the issue or you will destroy the engine. If the wiring checks out good, I would check the oil pressure with a gauge to see what pressure you are running at.
Old 06-19-2023, 09:27 AM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
My 1806 (M18) did the same thing and replacing the sensor fixed it.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 06-20-2023, 08:53 PM
Pray-2-miss-rocks Pray-2-miss-rocks is offline
Bob
You can try a mechanical gauge that you know is good
Old 06-22-2023, 10:09 AM
Farmall450's Avatar
Yes, or swap with another sensor. NAPA normally stocks them. I replaced a plug (from someone else's swap) with the proper sensor and restored the light function on my 1440.
Old 06-30-2023, 12:19 PM
Mr Bob's Avatar
Thanks to all that replied. Not feeling well past few weeks but I will use your advise and try to check it out. Thanks again and have a great day.
Bob
Old 07-01-2023, 12:47 PM
Mr Bob's Avatar
Default 1862 Oil Sensor
Can you remove the oil sensor by going through the grill housing after removing the grill? Looks like it would be difficult to get the replacement restarted in the threaded hole. Thanks and have a great day.
Bob
Old 07-01-2023, 12:59 PM
Farmall450's Avatar
Bob
Probably, but it's much easier to remove the wingnut, washer, and LHS panel.
