Old 09-03-2023, 08:26 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default 1862 mule drive belt size
Hello All. Anyone using an 1862 with a 44" deck? I need a new belt. One I took off had 5/8 x 90" Book says 5/8 x 89" My 1862 has a 6" front drive pulley. Would this require a 90" belt? Thanks in advance for all help.
Bob
Old 09-04-2023, 11:15 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
To properly answer this question, the assumption here is that your 1862 Cub Cadet was produced in serial number range 821060 - 836000.
So, if your 1862 has the correct recommended model 318 44" deck with the 6" PTO pulley size and 5 1/8" (756-3055) deck drive pulley size, the sources say to use the Cub Cadet part number 754-3023 B-Section X 93.7" long - now superseded to part number 954-3023.
If you are running the older model 358 44" deck, then your 90" belt would probably fit. The 358 deck has the 4.5" drive pulley (756-3007) to pair up with the 4.5" PTO pulley on the older Cubs.
If you use not recommended mismatched size pulleys, you will either have a very overdriven or under driven deck.
6" PTO pulley coupled with a 4.5" deck drive pulley equals an overdriven deck. (blades spin much faster than rated)
4.5" PTO pulley coupled with a 5 1/8" deck drive pulley equals an under driven deck.(blades do not spin fast enough)
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 09-04-2023, 03:29 PM
Mr Bob's Avatar
Default 1862 bet
Thank You 1711Cub I could find no markings on the 44" deck other than a 44" label. My Tractor came with a 6" pulley. The pulley on the deck is 41/2". It is a 44" deck as I measured the blades to be sure. I have a 50" deck that I will check the pulley size. Hopefully it will have the larger pulley. Thanks again for all the info and have a great day.
Bob
Old 09-04-2023, 10:07 PM
Farmall450's Avatar
I like the idea of an overdriven deck.
Old 09-05-2023, 08:28 AM
1711Cub's Avatar
Thumbs up
I have the overdriven setup on one of my tractors- the IH built 582 with a Kohler Command 20 swapped into it. I retained the original to the Command 20 engine 6" PTO, and used the original to the 582 44C deck with the small 4.5" drive pulley. I used a 754-3006 954-3006 belt which is 5/8" / 93".
It cuts fantastic. I'm sure that it goes against ANSI safety standards for that era tractor in terms of blade tip speed, but it definitely works!
