Old 05-27-2023, 12:18 PM
jfaison jfaison is offline
Default 1320 Losing Power
Good morning,
I am using my 1320 to mow this morning. It does not sound correctly and moving slow. It is cutting great. It worked great last year when I used it. I am seeing some light smoking at the exhaust. Here are three videos of the mower running. The choke cable is not working well and needs to be replaced. I believe this may be the issue.
https://youtube.com/shorts/6uyvp0qVkaA?feature=share
https://youtube.com/shorts/UxAz7B0_nPs?feature=share
https://youtube.com/shorts/__wFHLX-ShQ?feature=share
https://youtube.com/shorts/-aHqe-_w1YM?feature=share
Any help would be appreciated.
Thank you.
Old 05-27-2023, 01:02 PM
It looks like a rusted choke cable. The choke is not moving when the cable is adjusted at the console. I did a manual adjustment and it is running good.
Does anyone know where to order a choke cable golf or a 1320?
Thank you.
Old 05-29-2023, 11:21 AM
I have one more question. The hydrostatic fluid reservoir looks low on fluid. I doubt it has been changed. What do I need to do to change the fluid and what fluid should go in the reservoir? It there a filter that needs replacing?
The 1320 moved a little slow Saturday but cut over an acre. The grass looks great.
Thank you for your help!!
Old 05-29-2023, 02:50 PM
bill682 bill682 is offline
Choke control is part number 746-3026. Still available from Cub Cadet or MTD.
The 1320 owner's manual states the hydrostatic transaxle is a sealed unit with no filter and not serviceable.
