Old 03-28-2017, 01:20 PM
Joesprocket Joesprocket is offline
Default Cub Cadet 1330 Carburetor HELP!
Hi everyone - first post here. Have done a ton of research and finally electing to put my question into the wind hoping for an answer. The carburetor on my 1330, Command 12.5 (mid 90's model) is shot. It came with a Walbro 12-053-10. It's a discontinued carb that I can not find new or used. Local tractor supply in town recommends the Kohler Carb (12-853-140-S) as the replacement. Runs from $100-$120 on ebay and various online retailer.
My question is if anyone has had success with this Kohler carb or another carb that syncs up with the Command 12.5.
I'd really like to be as confident as possible before buying.
Also - i've read that paper fuel filters arent' great for these engines and should go with screen. correct?
Thanks so much!
Old 03-28-2017, 01:40 PM
Inactive Member
The 1330 rolled out of the Factory with a Kohler CV12.5-1211 Engine.
The Cub Cadet parts manual lists the OEM Carb as KH-12-853-01. That supersedes to KH-12-853-140-S.
The Kohler Parts Site states that the OEM Carb was KH-12-853-01... but is replaced by KH-12-853-57......>>> KH-12-853-139-S
If this were me, I would go with the information from Kohler. After all, they made the engine.
Old 03-28-2017, 02:24 PM
Here is one for $80.50
http://www.ebay.com/itm/like/1416707...&ul_noapp=true
Old 03-28-2017, 02:59 PM
Agreed - wonder what the difference is between the 139S and 140S? They both have the KH pre-fix. Does that mean both are made by Kohler?
Old 03-28-2017, 03:04 PM
KH means Kohler, BS= Briggs & Stratton, KB = Kubota ETC. What I do is to remove the prefix then do a Goggle search, example, "Kohler 12-853-139-S"
and see what comes up.
Old 03-28-2017, 03:53 PM
Thanks for this. After hemming and hawing for an hour or so I went ahead and purchased this. It's no different than the others that were $100+. Appreciate the heads up.
great help here.
Any tips on installing?
Paper vs mesh fuel filter?
Old 03-28-2017, 04:27 PM
Mesh. Paper won't gravity feed well. Believe me. I worked at a Case IH dealer who also sold Cub Cadet. In the early 2000's, I worked on one that the customer stated would die. I literally mowed for days with it around the dealership trying to get it to quit. As it turned out, the customer never said it would only do it when low on fuel. I kept the tank reletively full..... it was the paper element filter. Hate to know what they charged that guy.
