Old 09-13-2022, 03:04 PM
Ikea6e Ikea6e is offline
Default Fan Assist Bagger
Cub Cadet Fan Assist baggers are hard to come by.
Here is an alternative that you may like.
Used it once so far and it worked well. Will get a workout this Fall.
May be easier to mount on a 44 or 50 inch deck.
I don't have a 44 deck to try mounting this on. If I get one I'll give it a try.
Old 09-15-2022, 09:30 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
interesting. Did you buy the blower assembly new? Looks to be a simplicity blower. Please post a followup after more usage.
https://www.jackssmallengines.com/ja...mounting-group
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 09-15-2022, 10:09 PM
It is a Simplicity. I bought it used specifically to see if it could be adapted to work with my bagger. Had it and a Cub Cadet 1440 to tinker with over the Winter. I'll give an update after using it this Fall. I just picked up a 1641 with a 44 deck. The 1641 is a project for this Winter, may get to see how the Simplicity blower matches up to the 44 deck.
Take care, Ike
Old 12-03-2022, 09:10 PM
worked pretty good. Still may try in on a 44 deck.
It would mount further forward and have a better angle into the bagger.
Old 01-26-2024, 04:45 PM
Here is the Simplicity Turbo Blower mounted on a GT 48 inch deck. The 48 deck out let is further forward than the 46, This should give me a better angle on the hose going into the bagger.
Old 01-26-2024, 08:56 PM
Ozcub's Avatar
Ozcub Ozcub is offline
In your second photo it looks like there is a fair amount of tension on that top pulley
Is that standard or correct ?
Oz
Old 01-29-2024, 11:20 AM
Could be the camera angle. The first photo shows the tension spring attached to an eye bolt. The tension can be adjusted there.
When this unit was on the 46-inch deck it didn't need a lot of tension to run it. When I mount it for picking up leaves this Fall, I'll make sure there is not excessive tension.
Have to work on the chute into the bagger this Spring.
Old 01-29-2024, 06:44 PM
Ozcub's Avatar
Fair enough , those camera angles play havoc with my portrait photos
Oz
