Help With Electrolysis
Built my first electrolysis tank and it seems I failed some where. I attached pictures and will appreciate any help. First, is this the correct detergent? Second, could my negative wire be too thin? Is the charger supposed to show charging? When I plug it in the charge needle vibrates for a second or two and then no movement. I checked the positive circuit for continuity as I was putting it together and it checked ok. I read everything I could find using the search and thought I had a good understanding. Evidently I did not. Thanks for your help.
Bob |
Wrong soap. Washing Soda (Arm & Hammer, for example)
VERY different than laundry stuff. OH, yea, if the battery charger is fully automatic, you will need a battery in parallel with the charger leads. |
That's right
Washing SODA is what you need. I agree with the auto charger. I use an old, old, Sears charger because my newer and more nifty chargers won't work without a battery to let it "feel" the charge. I was frustrated a couple of years ago trying to de-rust an old plane to restore until I figured out that the "smart" charger was my problem. BTW, I think the negative wire size is fine.
The box you have looks similar but it is wrong. You need to look for this stuff. It is at most chain stores in the laundry section.
1981 IH Built 782- 44" deck 1650 dual stick 71 "121" round fender and replacement k301 carlisle tru powers and v61 |
I found that "drain cleaner with lye", seemed to work better. True value hardware.
I like your tank! NIK,
It dont cut grass, but its yellow. |
Yeah, I thought the tank was cool too. I always cobble something together and it looks worse than the item I'm trying to restore. I swear that the "next time" I'll make a better tank. Course, there's always the next time!
Help with Electrolysis
Thanks for all your help. Think I can get an old charger that is not automatic. Will get the correct arm and Hammer Soda. Are there any fumes or other dangers from using the Lye? Going to give it another shot this week.
Bob |
I agree with the battery charger thing...
I bought a new one off the net a few years ago when I built mine, it wasn't very expensive (about $35.00 delivered) it is not automatic, Schumacher is the brand name and it works very well. Instead of washing soda, I used Trisodium phosphate (TSP) I believe you can get it at the walmart or any paint store. I really like the idea of using lye as Nik mentioned, some day I may add some to my solution. You also need to clean your consumables often. I use 8 big old lawnmower blades and have to take them out and pressure wash them every day because they get loaded with crud and stop working (slow down is probably more accurate). The "crud" gets really thick on them, 3/16to a 1/4". Good luck with your project, if you plan your project and use your tank wisely an electrolysis tank can be a great asset to restoration work.
That ought to clean the crud off the anodes. If that doesn't work I could use a horse for the anode, and to clean it!! |
and no doubt has done so with very good results
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering JD 110H:JD 112H |
