1450 creeping
I need some ideas from outside the box I guess, because I injured my knee.
My buddy has been kinda restoring my 1450, and because he is very O C D, he has been adjusting the hydro shift linkage exactly by the factory specs. Every single piece of linkage has been inspected and adjusted, lubed, rechecked, and it still creeps. Tapped one way, then the other. Any ideas? Thanks in advance. |
I read on this site a while back how to fix the creep problem, unfortunately I don't remember where. Maybe someone can help you figure out how to access the repair tips.
Neutral adjust
Look for the arrow on the cam plate and center the pin on the plate assembly there to start with and slowly work your way either direction to find the sweet spot.
New or not loose used ends and snug pivot points are a must have to work your way around wear points in this operation. They all add up and magnify any issues. Shim what you can, will help a lot right there. |
