Old 09-10-2021, 09:46 AM
BDog69 BDog69 is offline
Default New from MD
Hello all,
Just joined after purchasing a used GT 2186-48 from a friend of mine. So far I love it. I have run into one issue though, and also have a couple questions.
1) It has broken the last two deck drive belts rather quickly, first time I could smell rubber right before it broke, second time i did not. All of the pulleys move freely, bearings seem fine, no noise, no play, etc...
2) There is a little bar in front of the two lower pulleys that moves, from research I see it is a quick latch assembly..what is it for and what does it do?
3) Only the lower front pulley on the right side has a belt guard. should there be one on the left pulley as well?
I searched the forum for the latch assembly answer, but couldn't find anything, same for the guard.
Other than these 3 things, I am very happy with the tractor and look forward to fixing the belt issue and using it for years to come. I also look forward to using and enjoying the forum seeing what others use their tractors for and how what they do to them.
Old 09-10-2021, 10:14 AM
IHCubCadet147's Avatar
Welcome to OCC!
Old 09-10-2021, 01:51 PM
ejl6658 ejl6658 is offline
This should be the model number for your 48" deck 190-301-100. Go to the website in the link and you can download the manual.
https://www.cubcadet.com/en_US/operatorsmanuals
Old 09-10-2021, 02:34 PM
THank you for the info
