Old 09-14-2015, 03:21 PM
ahirbe ahirbe is offline
Default 1015 Upgrade
First off, I want to say thank you for all the info you guys have put up here I have been an avid reader for a few months now and cannot express enough gratitude for all I have learned from the members on this site!!!
I hope this is an appropriate place to post this, as it WILL be a mod...I hope.
I have a Cub Cadet 1015 with a 10HP B&S engine. A friend is giving me a 25 HP B&S Intek V Twin and I would like to upgrade to it. I will get more info about numbers and models soon, but I am looking for generalities to see if it will work at all? I Would like some more power to push through taller grass and push snow in the winter.
THANKS
PICS
https://drive.google.com/file/d/0B51...ew?usp=sharing
http://www.onlycubcadets.net/forum/i...20Flag%201.gif
Old 09-14-2015, 03:28 PM
jimbob200521's Avatar
Links aren't working for me
-Ryan
Old 09-14-2015, 04:14 PM
PICS attached
here is a link to the mower manual the 25HP engine is coming out of...
It is a Troybilt 609
http://www.searspartsdirect.com/part...mManualTabPage
Old 09-14-2015, 08:15 PM
I'm sorry but I'm not sure this engine would be an "upgrade"
Old 09-14-2015, 09:45 PM
john hall's Avatar
I remember when those things were new--they were basically a beefed up Murray. That was the smallest tractor style mower the dealer dad worked for carried--probably was the smallest Cadet made. I think it came in gear and hydro drive (actually different model numbers if you want to get technical).Kind of surprised you are running short on HP with only a 2 blade deck. I'm afraid if you put that much HP under the hood you're going to demolish something, especially if you try to push snow with it. Best of luck to you! Keep us posted on how it goes!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-14-2015, 10:41 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
i think your going to wasting your time and money doing this. you wont know if it will physically fit until the old engine is removed. if it does fit then you will probably have to drill new mounting holes. then there is the pulley on the crank that drives the deck and tractor,the cranks may be different diameters. you have a lt which is a lawn tractor and is not meant for serious work. the stamped steel frame could buckle or crack under heavy loads from pushing snow. unless you have the mechanical ability and tools which includes a welder,i would pass on the 25 intek. perhaps your original engine is tired??? find another flathead briggs in a larger displacement instead.
Tags
1015
