NF spring assist
I spent about $20 dollars but I already had the piece of angle iron. I got a small clevis and hooked it to the lift arm to attach the spring. The angle is mounted to a bolt on the rear and a 5/16 eyebolt at least 6 inches long, hooked to the spring and through the bracket. Tighten the eyebolt adjust the tension.
All parts came from tractor supply. 2 inch angle, 1 inch wide The spring is the heaviest duty 1 inch X (about)10 inch spring I could find. 5/16 eyebolt at least 6 inch 2 5/16 nuts and washers clevis has 3/8 stamped on it,its about 2" long by 1 1/2" wide. Scott |
Nice job on the spring assist.
If it works for you, it works for me
Good thinking.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
