Old 01-20-2018, 06:16 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Default 2 bottom plow
Here's a couple pics of my custom built 2 bottom plow with a replica version of a Midwest Buster Bar harrow on my mini IH 5488. Got the plow all finished yesterday and will make its debut on March 31st at Phil Klines spring plowday. Here is a link to a walk around video of this unit from today as well.
https://youtu.be/V2UDP_jR5ZQ
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 01-20-2018, 06:38 PM
cadetmike's Avatar
cadetmike cadetmike is offline
That is a nice set up sir! Would like to see that Buster Bar in action, might have to put something like that on mine
Old 01-20-2018, 06:39 PM
Inactive Member
That is a fantastic job and I really like what I see.
Old 01-20-2018, 06:43 PM
jimbob200521's Avatar
You've got this built and here I am debating ordering a 3pt kit from Xtreme motor works excellent job!
-Ryan
Old 01-20-2018, 08:56 PM
dirtcowboy's Avatar
Thank you everyone I'm really looking to the plowday. I used the buster bar in mid December before the ground froze when we were fine tuning things before teardown to paint. The tractor pulls the plow great, it has two 10" Brinly bottoms on it with new shares on each bottom. I took it to a couple fall plowdays and it worked great and doesn't pull much harder than my cat 12" single bottom plow.
Old 01-21-2018, 02:25 PM
Fantastic job as always Jerry!!
Did you set up both plows to take a full 10" bite?
We had a Midwest Buster Bar on a 560 plow we had. I pulled the plow quite a bit, but never with the buster bar on it. They took it off before I started driving, but it sat in the shed for years, and the plow still had the mounts for it on it.
Nice work!!
Old 01-21-2018, 03:04 PM
john hall's Avatar
You do some really nice looking work! I've never heard of that Midwestern Buster Bar before. Learn something new all the time. If someone cares to elaborate on the "why" of the buster bar I would appreciate it. I would assume you run it in "clean" land to help smooth things out? I come from the land of heavy duty IH plows---its either a 450 IH auto reset or nothing--anything else is a joke in our clay and rocks. It takes a heavy duty harrow (disc) to level after plowing. The pic is not ours, we ran two 4 bottoms, both are long gone now.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-21-2018, 03:44 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
DIRTCOWBOY, that is a really nice job. Interesting that you say it does not pull any harder than a 12"!
Just order it. I'll have Keith post pictures of the one he bought from extreme. It looks like spaghetti. It'll make you glad you spent all that money
1- 1200 in pieces
1- 1864 in pieces
Old 01-21-2018, 03:52 PM
I pull an F145 (JD) 5-14's with the old 806, it handles it in any soil.
a 12'6 disk and packer does the leveling.
Just doing it the way I've done it 50+ years ago, and enjoying it.
Every year I ask myself, can I still physically do it?
Life is short.
Old 01-21-2018, 05:41 PM
Yep. Basically just a harrow. It levels things out enough that when you follow it with a disk, or whatever, that you don't get beat up as bad.
We ran trip plows here, but not spring reset trips plows. Ours were manual reset. We did it more for old oil flow lines than for rocks. Not uncommon at all to find an old flow line buried just 6" or so below the surface. BTW, the non spring reset sucks when you trip one that hasn't been tripped in 20 years. I found an old flow line in a piece of ground I farmed in high school. Caught the plow and tripped it. Like to have never got it reset. Finally parked it on an old grain bin site and hooked the share to the concrete and got it to reset! I tried it out in the gravel road and it just dug a hole!! Freakin thing was STIFF!
Life is short.
I can't decide if our soil is not as heavy here, as it is up north or what. We have tons of clay and our topsoil is only about 12". Some places it isn't that thick, and you hit clay. Shoot, some places, it is just clay. Anyway, I was just talking to granddad the other day about the IH 560 (6-14's) we had. He said they bought it and pulled it with the 806 gas! I didn't know the 80' gas would pull 6 14's. He said it did. (We plowed at least 8", deeper when we could.) Kind of explains why the 856D and 1066 didn't seem to mind the load at all.
