Old 10-08-2016, 12:46 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Kohler KT 17, 1 Cylinder no working?
Hi,
few Years ago, i rebuildt the Kohler KT 17 S2 of my 782. Now, the Motor have 56 Engine Hours, after rebuilding on it.
The Motor works now in my 1772, because the Diesel is in my 782.
Few Weeks ago, i attach a Harley Davidson Coil to it, because the Aftermarket Coil was damaged.
Today, i had to work with my 1772, but the Motor has not the full Power. Ignition is ok, the Plugs are sparking good. I disconnected the Spark Wires, first the left Side, than the right side.
After disconnecting the right Wire, the Motor stops.
I feel the Heads with the Hand, the right Cylinderhead was hot, but the left one was only a little bit warm.
I think, the left Cylinder is not working, but what can be the Problem?
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 10-08-2016, 01:23 PM
I would recommend starting off with a compression test.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-08-2016, 09:33 PM
First,
swap plugs to other side and see if the dead cylinder follows the plug.
If so, bad plug.
Second.
Since both plugs fire @ the same time,( wasted spark design) swap the plug wires and see if the dead cylinder comes to life.
If it does, you have a coil problem.
Old 10-10-2016, 02:49 PM
ihc353s's Avatar
Thanks for helping, spend the Motor a Set of new Spark Plugs, and now, the Motor runs how new,
mfg Georg
