Old 06-05-2024, 07:28 PM
1811woody's Avatar
Default Cyclops head light stand off repair ideas??
Has anyone had to repair the above mentioned, how did you do it? Or use an led option that doesn't use these mounts? Update I got it figured out thanks for the input guys.
Old 06-06-2024, 08:51 AM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Good question, I tried to use gorilla glue to repair mine
My fix lasted less than an hour
Old 06-06-2024, 10:08 AM
Here, get some of this stuff
This stuff is awesome!
I used it to repair multiple breaks and cracks on a 2182 a few years back and it works!
Plast-Aid
www.plast-aid.com
Old 06-06-2024, 01:40 PM
1811woody's Avatar
I'll check into it thanks for the tip
Old 06-06-2024, 06:32 PM
dale c. dale c. is offline
take the lens out and drill holes and use machine screws with nylock nuts
Old 06-06-2024, 07:50 PM
1811woody's Avatar
I've considered doing that and incorporate spacers if there's not a better option
Old 06-12-2024, 12:09 AM
Rex B Rex B is offline
I repaired mine with Gorilla glue, waste of time and money. If I were to do it again I would use the JB Weld Plastic Epoxy. That stuff works.
But mine are too far gone to repair. My plan B is to find one of those rectangular LED off-road lights fit it to the cowl opening.
Something like this
I mean, if it's a cyclops, it don't need two eyes - right?
File Type: jpg ca8f058823cf41147b2bff405ad24c79-783603888.jpg (19.7 KB, 58 views)
Old 06-12-2024, 10:13 AM
1811woody's Avatar
I've looked at that option as well in fact there's one sitting in my shopping cart but my wife won't let me out past dark so it hasn't been a priority lol
Old 06-12-2024, 01:48 PM
IHCubCadet147's Avatar
Here’s what the PO of my 1440 did. IMO, they look better from the front than 1 longer bar would. I would not recommend hacking up a nice grill to do this unless yours is already beyond repair, but they do work and are very bright. As you can see, the whole bottom of my grill is missing.
File Type: jpg 6F5A7A3A-27EA-4C25-B7F0-345343D2DB2B.jpg (33.1 KB, 50 views)
File Type: jpg 989F852D-A419-4C08-BE9D-671C1299AFDA.jpg (36.2 KB, 50 views)
File Type: jpg 747EC711-A450-489C-8012-C891B99ED8F5.jpg (19.8 KB, 50 views)
Old 06-12-2024, 02:26 PM
I recall on one of my old 2182, it just being brittle from age. I found one of the dealers still sells them, maybe messicks, probably a Chinese knockoff but it fit fine and was a bit too shiny but it was easier than battling the cracking. It’s was 150-200 range in price. I think if you are keeping the tractor it’s just going to get worse and better to buy a replacement when you can since cub discontinued them.
I do run LED PAR36 lights to keep the heat down and reduce cracking
