Old 10-14-2018, 05:29 PM
Default Will it work? 190-321-100 on 1050?
Thank you to all who helped get this old girl 1050 back to life again in my other thread. Got the driveshaft put together and installed this weekend and it runs great.
Here’s a question for you later model gu ru’s as I’m still a little green with the spread frames. I have the ability to do some horse trading for a 46 GT deck (190-321-100) that’s decent and a mule to go with it. Needs an idler and blades but only used one season. By the pictures it looks like one of those vacuum decks you guys mention. Anyway, will this mule and deck fit with no issues or will I have to modify something? Also, will the ten horse be able to handle it? I think it should be ok, we cut our grass here very tall and any mower really doesn’t have to work hard as the grass blades are very thick and dense on st Augustine floratam grass that I have and I don’t get any clogging on the small timed deck all the way up to the haban. Feel free to talk me out of it but wanted some real world experience pros and cons.
Old 10-15-2018, 06:40 AM
Inactive Member
According to Cub Cadet, these are the Mower Decks available for the model 1050:
* 190-357-100 - 38C Deck
* 190-358-100 - 44C Deck
I suppose other decks could be made to fit and work with modifications and alterations.
Old 10-15-2018, 09:00 AM
I think Sam had a 46" gt deck on a 1211 so it's doable, hopefully he will post up about how he did it cause I'm a little curious also.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-15-2018, 09:39 AM
cooperino's Avatar
My 1211 is running a GT46. Works great!
Old 10-15-2018, 12:49 PM
Thanks for the responses guys. A naughty little bird told me that the pto pulley is a different size diameter on the cyclops versus the older series and the rpm would be questionable?
Coop did you mount yours or was it on there?
Old 10-15-2018, 01:18 PM
cooperino's Avatar
I got it this way. I can take some pictures for you later probably. I think the pulley was changed on it
Old 10-15-2018, 07:07 PM
I did but that was after I repowered it with a 16hp Vanguard out of a 2160 so it had the big PTO.
Old 10-16-2018, 06:20 PM
cooperino's Avatar
Couple pics if they help
I know... I need a new deck belt. My idler pulley bearing started to lock up lol
Hope this helps
Old 10-16-2018, 08:20 PM
Thanks Coop. Can you measure the pulley diameter of the pulley on the deck that the belt goes around that comes from the engine as well as the engine pulley diameter for me? Thank you in advance
Old 10-16-2018, 09:15 PM
cooperino's Avatar
Yup.. it's dark out there now but I will get it asap
