Old 07-31-2016, 06:28 PM
JLM78's Avatar
JLM78 JLM78 is offline
Default Electric Fuel pump
What Electric Fuel pump do you guys use on a 782 replace the stock one?
Old 07-31-2016, 06:51 PM
For a 782D? Or a 782?
I know you have that gasoline one, but they used a mechanical pump. I replace the mechanical pumps with Prime Line replacement pumps. Cheaper, and seem to last.
For the diesel tractors, you can get a replacement fuel pump at most all part stores. Just make sure to get one specifically for diesel. They usually run about $40, IIRC.
Old 07-31-2016, 06:54 PM
Both my stock kohler engines are mechanical, and work well.
If you want electric, it should be low volume and only a few pounds pressure,
#3-4 maybe.
Old 07-31-2016, 06:56 PM
Ironically there's a Write up in the latest cadet connection magazine. He uses a Facet model 40177 pump. 7 gpm at 1-2 psig and has a check valve . Hope this helps Jason.
Old 07-31-2016, 07:41 PM
JLM78's Avatar
A 782 gas one
Old 07-31-2016, 08:17 PM
Inactive Member
Here ya go...........
Old 07-31-2016, 08:27 PM
JLM78's Avatar
Thank you ........
Old 07-31-2016, 09:40 PM
DieselDoctor's Avatar
Yep! Made in the USA, upstate NY to be exact, about two miles from my house. I have a couple friends that work at the plant and they do extensive testing on the pumps. It's a quality product. To ensure a long life with any pump, keep your fuel clean.
Old 07-31-2016, 10:06 PM
CubDieselFan's Avatar
Yep the fuel filter goes on the inlet, between the tank and the pump. I have one on a 1811.
Old 08-02-2016, 09:12 AM
JLM78's Avatar
Were Did buy that at I Can find the pumps . I can't find that part number.
