Mule for tiller attachment
I read in Wild Bill's article tilling 101
It states that I need a different mule for the tiller. My question is; can I get any mule and adjust the pulleys to work with the tiller, or do I need a mule just made for a tiller? ole 147 _____________ Anything worth having is worth keeping nice. |
If you have a wideframe with a 44 or 50" deck, you'd need a mule drive without the angled pulleys. Regardless of the deck, you need to put a tensioner on the spring-loaded idler in place of the spring so you can tighten the belt properly.
I have a 104 NF I just found a mule but it's like the one that is on tractor now. I could set that up to work with tiller. What do I have to do to it to make everything work properly? this is what I have Matt. ole 147 ______________ Anything worth having is worth keeping nice. |
Matt could you explain please. What parts do I need for this? I must be slipping. Blank look. I have a 104 ole 147 |
Can I modify it to work with the tiller? I'm running low on funds for this project. (Need smiley for broke.) May be someone has mule that would trade? Thanks ole 147 |
Here is a pic of my extra mule drive:biggrin2.gif:
Thanks for you help. ole 147 |
I don't know 100% sure if it would work but it does have the bolt on the tension pulley that's needed for the tiller.
If you get rid of the spring and add another tensioner bolt, that will work. I'd replace those rusty pulleys, though...they'll tear up a belt really fast.
OK, where do I get what I NEED? ole 147 |
Cub Cadet dealer, forum sponsors, etc...
