Old 01-15-2014, 10:36 AM
dbuck dbuck is offline
Smile K-series points ?
Has anyone tried Chevy points on a stock engine/or slightly modified engine? I know the pullers used them. My way of thinking is with Chevy points it would be easier to set the timing with a light.
Old 01-15-2014, 01:49 PM
austin8214's Avatar
Not worth the added cost. I have them on my open RPM engine only because the Kohler points will float at high RPM. I tried using them on my stock engines and to be honest they were more trouble than they are worth. In fact I had two different experienced engine builders tell me to get rid of them.
Also set timing using the static timing method and don't worry about using a timing light.
Old 01-15-2014, 04:32 PM
Honestly..... how often do you have to set the points that it needs to be easier?
Old 01-15-2014, 09:22 PM
ClickClickBoom ClickClickBoom is offline
I'm using them. Setting the stock points is an exercise in frustration. Much easier with the chevy points.
1872 W/ Kwik Way loader
1650 W/ Dual Hydraulics, and rear lift
Cadplans Caddigger
qa36a blower, tiller, and snow blade
Gannon Earthcavator
Old 01-15-2014, 09:39 PM
bocephus1991's Avatar
It can be aggravating yes,but better to stick with the stock points heres a link to how to static time. Start by setting your points at .20 and go from there.
http://onlycubcadets.net/forum/showthread.php?t=4405
Brian
Old 01-16-2014, 09:32 AM
Talking
Ditto, with the timming hole being on one side of the block and the points on the other side. Unless you are a contortionest (sp) or have a Buddy that you trust with a timming light. Although the cost maybe a little high I can see where using Chevy points would be easier. I do have a K-301 with David Kirks points saver installed for the last 3 years and I never replaced or adjusted the points. It fires right up and runs strong. Thank you Guys for your replies.
