1450 moves at idle
Recently acquired cub cadet 1450 hydrostatic will only move forward or reverse at low idol once you up to the RPMs it gets a vibration will not move forward or reverse and sounds like a bad powersteering pump on a car
Let's start with the basics. Did you check the fluid level in the transmission? There is a plug on the rear of the tractor. Take it out, there should be fluid up to the hole.
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
Rudy welcome to OCC. First place I would start would be changing the hydro oil and replace the hydraulic filter.It sounds like your filter is plugged up to me. What part of NY are you from. 1/2 hr south of Syracuse here.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
I would start with a fluid/filter change, these things do all kinds of crazy things when the filter is plugged. The whining sound you hear suggests that the rearend is low on fluid and sucking air so dont be surprised to find a few leaks once the fluid is full.
yep it is "cavating" (not getting oil to the pump) Do as others said!!
As old as it is, prolly better to take off the rear cover and clean all the nasties out of there and replace with new fluid and filter. Welcome to OCC!. |
Along with the fluid and filter ,check the driveshaft could have sheared a roll pin . That with could explain why it will move at idle but not once you put some strain on it.
Bob |
More than likely the problem, but it is good to change the fluid as it is unknown to you when it was done last.
So thanks for all of the help I pulled the cover an I have the gelatin balls in my brown as heck fluid I've sourced a filter locally Id like to find an acceptable substitute for the fluid what would work in the ol 1450 is the only fill hole for the hydro/transaxle in the cover ? Thanks again
Make sure you get the correct type of filter. Some crossed numbers are not correct. Best bet is a Wix 1410, or Napa 51410.
You can substitute the oil with most any tractor hydraulic/transmission oil. TSC, Rural King, Farm and Fleet, Napa and O'Reilly's carry a version of it. It is best if it says it can be substituted for IH Hy-Tran. |
