XT1 LT46 Fab EFI PTO will not engage
Mower starts and runs fine but blades will not engage.
So far I have done the following: Tested the pto switch it tested good, replaced it anyway and it didn't fix it. PTO clutch engages when I wire directly to battery so clutch appears fine. I replaced the ignition switch module which didn't fix the issue. Changed out the solenoid which didn't fix the issue. Mower starts so don't think it would be the seat safety switch. What should be my next move other than take it to the repair shop? Also considering running a wire directly from the battery to the clutch with a toggle switch. |
Just keep throwing parts at it, you will either run out of money or fix it
Or: You could systematically follow the wiring diagram and find the problem through process of elimination, your choice. |
Having trouble finding the correct wiring diagram
What is the complete model number? It is on a white tag, usually attached to the frame on the front left side.
13a9a1cn010
