Bench Testing M18
I've bench tested Kohler K engines with easy, however I have never bench tested an M18. Does anyone have any advice? As far as supplying battery power to the coil and starter and ground, anything else I need to know? Will pulling the ground cable shut the engine off?
Chris |
You only need a battery to start the engine. The M-18 has a magneto and does not need a 12V ignition source. To stop the engine, ground out the "kill wire",
That sounds simple enough. Which wire is the "kill" wire and how do I ground it out?
Chris |
Dr. Bedell I see a new bench test wiring diagram in the works LOL The third of many to come like you have nothing else to do.
Thanks for the help Dr. Bedell.
