2182 wont charge
Got a 2182, with a Kubota gas engine, positive battery wire touched the exhaust and melted the coating, but didn't seem to hurt the wire, but now it doesn't charge thought was the rectifier/regulator but that didn't fix it, is there a way to check the alternator on this engine only 2 wires coming out of it. just wandering if anyone knows what voltage and amps is suppose to be and where the regulator don't even showing its charging. thanks Newt
Which positive wire?
To test the alternator, disconnect the two wire connector from the alternator. Using a DVOM, set it to A/C voltage. One lead on each of the two wires, engine running WOT. You should have approx 30 volts AC on them. If you do, the alternator is working. Did you check the fuses? Did you check to see there is 12V coming from the R/R? |
What do you mean R/R and the only fuse I seen is the one right by the battery
R/R= rectifier regulator.
Queen Of The Quietlines! |
