Kubota parts
Hi all, Just got my 2nd 2182 with the Kabota engine, and I'm having trouble finding a valve cover gasket for it.{Partstree has them for $26.00 each} Anyone have a good parts source for this Cub? I'm tempted is just using RTV silicon instead. I hope I don't need to find important parts that I can't get. Any info would help. Thanks, Don
Look up the cub cadet part number which should be something like KB-xxxxx-xxxxx. Remove the KB and search for Kubota parts. For example one of the 2182 models uses a KB-16861-14522 for the valve cover gasket (basically an o-ring). From Cub that part is $25 bucks. The same part number (16861-14522) from an online Kubota dealer (http://www.messicks.com/partdetail/16861-14522.aspx) is $7.37.
You will find it is much cheaper to get your Kubota engine parts directly from a Kubota dealer. You just need the part number. I have also heard about someone making that gasket out of a large o-ring. They cut it to the correct length and glued the ends together. Good Luck |
Yep if you need Kubota parts try the Kubota dealer. I just had to buy a set of keys for my 1782 because I screwed up and didn't take the key out when I loaded it on the trailer, needless to say it fell out on the way home. Cub price $26 something I got them from the Bota deal for about $7 Same goes for Kohler and Briggs parts.
WOW, Thanks. That worked great. now I know how to order Kabota parts.
Thanks, Don |
My local cub cadet dealer is also a Kubota dealer.
Also helps that I know all the parts guys. I tell 'em to look up the cub parts, transpose them over to the Kubota parts, and pay usually 1/3 to 1/2 the price. Gotta love the Cub, err, MTD markup.
Josh Diesel Cub Cadets........... |
I get my Kubota parts from http://www.m-and-d.com/. The gasket that was mentioned is $ 5.52 there and was superceded by number KB16861-14522. When I needed a water pump for my 782D, I got one there at a much cheaper rate than I could get anywhere else.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
