Uh oh! this is new.
Looks like I have some work to do. Oh well, It'll be fun...yeah, fun.
Randy 1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift |
winter time is coming, good excuse to get out of the house!
Where is it leaking from? The cork gasket? Relief valves?
Queen Of The Quietlines! |
I haven't looked yet. After I got it home I just drove it down the driveway and back, then parked it in the garage.
Just marking its spot is all. I mean heck harleys do it and they seem to still bring good money!
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
Well it could be a cork gasket,expansion plug,
valves, charge pump "O" ring, other 4 seals seals on the hydro, suction tube and oil filter, to name a few. |
internal brakes
Looks like you have internal brakes. As it looks like your machine is pretty clean, and appears to have just started, I would give it a good look over from bottom to the top.
Gary 1974 1650 50A "budscub" Was my fathers 1969 125 42" 1978 1450 44A dual hydraulics 1984 782 50C dual hydraulics, waiting for vanguard Z-force Cub cadet Zero turn Sears '66 Suburban 10 Sears '66 Suburban 12 2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow 74 "Green 100 "John" |
Yeah, I had a similar situation last week, except running down the steering box. Was about to throw a fit because I just rebuilt the steering box. Then realized it was running down from higher up. Took off the tunnel cover. Found out, when I rebuilt the steering box, and tightened up all the lines, one of the steel hydraulic lines turned just a little and was rubbing against the driveshaft and spraying hydraulic oil in a tiny stream everywhere under there, all down into the deck, everywhere because the spinning driveshaft made sure to distribute it. Luckily the line was still available. A $50 mistake. One thing I hate is when I cause the problem, but I guess that's how you learn. Could have been worse I guess.
A well oiled deck don't rust
