Greg Rozar AKA- CubDieselFan
Old 01-03-2017, 04:03 PM
mhasewinkle's Avatar
mhasewinkle mhasewinkle is offline
Good job on your 72! Very nice
Mike
70, 71, 72, 73, 100, 102, 125, 124, 128, 147
1200, 560 Farmall, 340 IH, #2 cart
Old 01-04-2017, 12:19 AM
Originally Posted by ken6x6 View Post
doing some winter maintenance on the 127. everything on the drive shaft is shot. got $270 worth of part coming. i decided to make the tunnel removable. its just to much of a pain to work on these narrow frames with that tunnel in place. i just drilled the spot welds out and ill replace the holes with nuts and bolts.
Ken, if you want it to be removable, and have no one know that it does. Weld either some all thread, or bolts in the "cover" where the spot welds were and grind the heads off and smooth out the area with bondo, and paint.
Attach your washers and nuts underneath, and no one but you, and well some of us will know the tunnel isn't permanent.
Old 01-04-2017, 08:08 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
thanks Todd, good idea. ill look into that.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 01-08-2017, 11:18 AM
Bamafan's Avatar
Bamafan Bamafan is offline
Well to start. I bought a wooded lot that joins my property and for the last week or so I have been cutting the small trees for fire wood to use in my shop.
To get the wood to my wood stack I thought this would be a good time to put my restored 1450 to work. I hauled several loads and the 1450 worked like she should (a sweet running machine).
Parked her back in the shop. The next morning I went to do some more hauling and there she sat with a large puddle of oil under the rear.
I got onto the forum and began reading and after much investigation it seems the dreaded cork gasket is leaking and a small seep of oil around the internal brake plunger, thinking this could be the o-ring.
I ordered parts and should have them next week and the repair will began.
I have read several post on the cork gasket repair but haven't seen anything on how to replace the o-ring in the brake. Any help on how to get it out and replaced would be appreciated.
Larry
Old 01-12-2017, 04:26 PM
SwampRatt-1977's Avatar
Pushed some snow today
Old 01-13-2017, 07:08 AM
Nice work SwampRatt-1977
Good looking Rig
Old 01-14-2017, 05:28 PM
CSXengr's Avatar
CSXengr CSXengr is offline
While some of you are dealing with the white stuff, I thought I would encourage you today. Remember spring isn't that far away! While some of you are plowing that stuff I plowed my garden today!
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 01-14-2017, 05:30 PM
Originally Posted by CSXengr View Post
Attachment 81397
Attachment 81398
Nice, you have to rub it in.
Old 01-14-2017, 06:46 PM
twoton twoton is offline
Looks good Gary.
Old 01-14-2017, 11:16 PM
Yes sir, rub it in. Someday we may see dirt, someday...
