Old 06-10-2011, 03:53 PM
scobar scobar is offline
Cool New Z-turn
Hello all and I am stumped with my 2005 Zero turn. I couild not find anywhere to turn but here with the experts, so here I am.
One of my hydrostatic motors has stripped the spline off the drive pully and shaft. CC will only replace the entire Hydro unit which is $1,300, ouch I said to that one. What I am trying to find is who the manufacture of the hydo unit is. The model of the mower is 53AA5A61710 and the p/n of the entire hydro is 01008193. HELP GRASS IS GETTING TALL !!!
Sccbar
Old 06-10-2011, 04:09 PM
One of my hydrostatic motors has stripped the spline off the drive pully and shaft. CC will only replace the entire Hydro unit which is $1,300, ouch I said to that one. What I am trying to find is who the manufacture of the hydo unit is. The model of the mower is and the p/n of the entire hydro is 01008193. HELP GRASS IS GETTING TALL !!!
Sccbar
I went to partstree and with the model number you gave me I could not look up the part with it. What's the model painted on the side of the mower? The complete unit list for $976.33. They must be adding labor to the cost.
Part Look up
http://www.partstree.com/parts/?lc=cub_cadet
Part cost
http://www.partstree.com/parts/?pn=01008193P
Old 06-10-2011, 04:58 PM
Duke
I called Parts tree too and they got me a PN HG50302 for the pully $21.24. At the time parttree (Robin) was not able to tell me the hydo model other than is is a Hydro-gear. I went to Hydro gear site but could not find the PN form parts tree. I am going to tear it out over the week end and see I can find numbers or something on the case to ID it. As a FYI the $1300 from my local dealer was cash & cary for the unit
Scott
Old 06-10-2011, 05:05 PM
Default mower model
I forgot to list that 53AA5A6L710, but you (duke) did found the correct hydro unit. It is a Hydro-gear, again looking for the Hydro-gear model for the entire unit, just as a FYI for future use, but I may need the shaft connected to the pully as well.
Old 06-16-2011, 10:52 PM
Vince_o Vince_o is offline
YOU NEED TO CALL ME ILL BET I CAN GET IT FOR YOU CHEAPER!
86FOUR 88FOUR 057FOUR
depending on what modle you have I got to where I could drag them threw the door, sawp the trannies, and back out the door in 45 min. Cub pays 1.5 hrs on the job.
Old 04-14-2013, 03:16 PM
greener14519's Avatar
greener14519 greener14519 is offline
Sccbar
Great! Another thing to watch out for on my RZT. I think mine is a 2004 RZT 50. Mine likes to spin the splines out of the rear hubs. And the hydros burn out (I run mine pretty hard on steep hills) so I've found a trick to service them. I drilled a hole in the bottom, drained the fluid and tapped the hole with a pipe plug. I refill them with Mobil 1 synthetic oil and they go right back to working. Last time I priced out a hydro unit, I think it was about $730.
