Old 03-24-2013, 11:05 PM
Jumper Jumper is offline
Default Front hydraulics on a 982....Part 1
I needed front hydraulic connections on my 982 to run different options, since my 982 only had a single spool valve I picked up a 3 spool valve from Epay for around $40.00 last summer that came off a John Deere. I was going to modify a twin lever for a two spool valve but it must have come off a 782, it was 3/4" too short so I had to modify the single lever that came off the 982. I bought some bushings and flat stock from tractor supply and modified them a bit and tacked everything together. I had a striped 982 frame in the garage and used it as a test dummy to fit up the valve, worked out pretty good. I still have to modify the valve mounting plate and plumb up the hydro lines and connectors to the front as play money allows, that will be part two.
Old 03-24-2013, 11:19 PM
Let me know when you are gonna buy your hoses, I want to buy stock in Parker that day!!
Looks great!!
Old 03-24-2013, 11:46 PM
Looks great!
Old 03-25-2013, 06:06 AM
Nice job!
Old 03-25-2013, 08:12 AM
Thanks guy's, now that I know it works I can start the finish mount and think about plumbing. I really like the 3 spool, as looking at it in the picture the spool on the left has a "float" position which will work good on one side of the front. It also has a power beyond port for at least one more hydraulic valve option in the future, who knows ?
Old 03-25-2013, 08:25 AM
ken6x6's Avatar
ken6x6 ken6x6 is offline
planing ahead never hurts.
127 - 48'' deck + tiller.
1512- 46" GT deck & bagger
1872- 60" Haban
Case 580CK
Ford 850
International TD-8E
Old 03-25-2013, 09:09 AM
mmzullo mmzullo is offline
Nice job. Keep us posted.
Old 03-25-2013, 09:56 AM
Looks great!!
Think I'd go tube for that job.
Old 03-25-2013, 11:18 AM
mmzullo: Sure thing.
Sam: My thought's also.
Old 03-25-2013, 01:15 PM
Great job! Looking forward to your updates!
