Old 07-09-2022, 02:35 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default 50c on 1450
What if anything do I need to change on a 50C to make it work on a QL?
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 07-09-2022, 02:40 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Obviously will need the correct mule drive for the tractor and deck. The newer 82 series tractors used a 5/8" belt versus the 1/2" belt of the older tractors, so a correct deck drive pulley will need to be sourced.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 07-09-2022, 03:25 PM
Am I mistaken that I could potentially use the pto from an 82 series? Not that I need to, just wondering. I've already got it switched.
Old 07-09-2022, 04:25 PM
1711Cub's Avatar
Thumbs up
Yes, that would bolt on your engine.
Old 07-09-2022, 04:36 PM
And that would make adding a bigger snowblower a lot easier
Old 07-14-2022, 09:19 PM
Farmall450's Avatar
Good upgrade all around.
Tags
50c
