44A deck spindles
I need to replace the spindle bearings on my 44A deck. Parts Tree shows them at $183.27 each. The part # is IH-ST745 and it updates to #759-3479P which looks nothing like my spindles. Has anyone updated them to another style? I don't remember when I had them apart if the bearings are removable from the shaft or not. I pumped them full of grease at the time and they felt smooth but after running the mower they were pretty noisy. Any help appreciated.
Jim |
Jim, I get new, original style bearings from Sterling Farm Equipment in Sterling or Medina Ohio. They are roughly $80.
Queen Of The Quietlines! |
Jim
The early style are what's called water pump bearings they look like the bearings in the pic. The later spindles use tapered cup and cone bearings. IH-ST745 http://www.cubcadetpartsnmore.com/#/...0-A/0074200002 IH-ST745 $159.08 759-3479P http://www.cubcadetpartsnmore.com/m5...ssy-w-o-p.html 759-3479P SPINDLE ASSY W/O P Your Price $159.08 Post a pic of what you have or get us the numbers off the deck. If you have the later style spindles you can replace just the bearings and seals.
Sam...I get the St-745 style bearings from the dealership I posted.
These pics are from a 44GT deck showing the later style housings and bearings.
44A deck spindles
I'm pretty sure mine are the so called "water pump bearings". I'll have to get the deck out and disassembled. It was originally on the 108 I restored but I want to install it on the 1440 Hystat that I had the breather problem with. I'm working on a different cub right now so when I get this one serviced I'll start on the spindle bearings. It doesn't look like there is any economical fix at this point.
I'm just trying to get something lined up for it at this point. I thank you all for the input and I will be back when I get started on it. Jim |
Jim
You may run into a problem with the center pulley. The 1440 would use a wider belt and the 1440 has the large diameter PTO.
seen those water pump style bearings on FeeBay for $75-80-ish ea, have to search a bit
I think this was mentioned about the belt width before somewhere. I have the pulleys off of the original deck for the 1440.Ill just have to check this out. Thank you Sam.
Jim |
Jim
What is the original deck for the 1440? If the shell is shot you may be able to salvage the spindles for the 44. Post some pics of both decks.
