Old 05-25-2015, 04:41 PM
bocephus1991's Avatar
Default Got a welder too!
Here's our old welder we had too. Looks pretty rough. It's a century 5-star ac/dc 250 amp . Have some cleaning up to do and see what's wrong with it. Got my fingers crossed! I got our old battery charger last year and the fan wouldn't turn. It had mud dobbers nests in it. Some kroil and wd-40 got the fan running like new.
Brian
Old 05-25-2015, 09:49 PM
I have a Century like that. It was my Dad's.
Been a good Welder.
Old 08-09-2015, 06:38 PM
freedhardwoods's Avatar
freedhardwoods freedhardwoods is offline
Older is better in many cases. That ought to last you a long time.
Old 09-24-2015, 04:05 PM
OldSkull's Avatar
OldSkull OldSkull is offline
5 pages long thread about that welder here:
http://www.tractorbynet.com/forums/w...tar-ac-dc.html
If you get it for next to nothing and can fix it for cheaper then dirt It may worth having fun with it! They are good machine for their time with good duty cycle but compare to a small inverter tig /stick unit of today they are big heavy dinosaur so don't spend all your weekly beer change to fix it.
Gilles.
1963 100 (red)/in storage
Old 09-24-2015, 11:04 PM
Some interesting reading there, thank you! Dad bought the welder from local AG COOP back in the 80"s. He used it some but was never very good at it. He took some night classes on welding. I'm self taught, then learned lots more in AG welding in high school. I've done some mig welding just not a lot . I've used it a couple times since I brought it home. It needs some work, fan doesn't work. Have our old century battery charger fan didn't work half the time on it . Took back off cleaned it, put some wd40 on the fan motor and it works now! Guess she was a little dry.
Brian
Old 09-24-2015, 11:33 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Brian,
I tend to go for that older stuff also.. it's usually built better than anything made today.. We have an old Sears arc welder that we never could burn up.. Dad built a bunch of log splitters with it back in the 70's and 80's.
It still works but we don't use it much anymore.. I got a Miller wire welder in the mid 90's that has taken over duties. Still handy to have an arc welder around for the HD welding though.. A 3/16 7018 rod with the heat turned up will burn through rust and paint that a wire machine will just laugh at.
Tig stick and mig all have their place and all require different levels of skill.. but the mig is probably the most versatile and the easiest to master.
Jay
Proud owner of the following:
Old 09-26-2015, 02:52 AM
I used lots of 6011 welding, versatile rod. We did have some nickel rod, now that was some hard stuff! We used some cutting rod too, didn't have a torch. A friend of my dad sold stuff for crontron back in the day. I prefer the older equipment, better built like you said! Like our Cubs! Have an old classic upright air compressor from my dad too. 80 gal bought from orscehlens in the late80's. I brought it home a few months ago. Hadn't been used for 17 years! Works fine! Love using it to take the blades off the mower deck
Brian
