New to me loader
I got the loader mounted and working, even though the tires are filled with washer fluid I'll still need a some ballast in the back so that comes next. Here's a few pics.
Looks good. What do you plan on doing with it? Is it a 1872?
Looks handy as he!!
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
Yep ITS A 1872, I plan to use it around the property, clearing snow, cleaning up mud after the spring flood trans porting mulch etc... I'll also get clamp on forks for my own personal fork lift
It will be I'm sure, I had a Johnny bucket on it it was great but this has the reach and ability to reach the top of my yard trailer to dump that the Johnny bucket didn't have.
I have 1882 with loader. I have the wheels loaded which added 100lbs per tire and I have 100lbs of wheel weight per tire. I have had it together for close to a year now and have yet to pick up the rear tires. I do run out of traction before I run out of power so I could still use some more weight. Eventually I would like to get some of those smaller 40lb suitcase weights to hang off the back but hard to find a deal on those around here. I am happy with the tractors abilities the way it is now and I worry some if I made it where the wheels wouldnt spin then what would be the weak link you know.
