Cub Cadet 2166 puking oil out of breather tube
I just bought a 2166 with CH16S-45509 motor. The whole underside if the hood was covered with oil and gunk. I was told it was the PTO seal. I took the mower to the car wash. After it dried, the seal appeared dry. The oil was coming out of the breather tube. I checked the read valve and replaced the head gasket. I still have the problem. Any suggestions ??
First, welcome to OCC...........
A leaky crankshaft seal can make the engine pump oil out of the breather. While you're checking the front seal, see if you can move the crankshaft up/down.
If you're compression is good, I'd think you have a crankcase sealing problem somewhere. |
is the oil level higher than it should be.... does it smell like gas?
Oil problem on 2166
When I first got the mower the oil was over full and smelled like gas, I changed it and replaced the carb. The old one had rust and dirt in it. I have replaced the head gasket. I am afraid that the old owner ran it a lot over full because of all the mess under the hood. I need to do a leak down test, to see if he took out the rings.
A needle/seat not closing properly or a ruptured diaphragm in the fuel pump are 2 reasons. If you replaced the heads gasket you saw the condition of the cyl walls. An engine will make a real big mess running only a short time vomiting it's diluted lubrication out the filler tube. Good thing is it keeps things from rusting |
Oil problem on 2166
I found out the fuel pump diaphragm leaks fuel into crank case waiting on new fuel pump.
