Wide frame hydro lift on a narrow frame
so my dad has a 147 and i just picked up an 1811. i have the long lift cylinder from a 1450. i have taken the rear end out of the 147 and mated the ported hydro pump from the 1811. now the question is where should i mount the lift valve? i dont think it will fit on the steering shaft... any input or pics?
On a custom build, it's up to you to solve the issues you run into. Mount it wherever you want.
Yeah I kinda figured but was curios as to if anyone else has done this. I'll take some pictures along the way
Nightow1 and I are going to do this on his 147 when we get around to it. Havent personally seen it done yet, but then again, we aren't stopping with just adding a hydraulic lift...
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
Well had to have 2 32" hydraulic lines made and picked up a few 45 and 90° elbows. Everything is on and functional. Just have to fab a lift rod, seal the tube that does from the rear end to the pump (slow leak) and put the fenders on. Pretty simple conversion.
Lift rod assembly. Have to remake the flat stock with some thicker steel but it's done and functional.
