Old 06-25-2023, 07:42 PM
Mn Cub Mn Cub is offline
Default 3165 Hydrostatics not working at all
Hi - 3165 - nothing works (steering, deck lift, F/R) - figured the gerotor broke (replaced about 7 years ago) - but was OK - however, put new Gerotor Housing Assembly just to be sure since I thought that was going to be the problem - did have to use the old shim - looked ok. Put new oil in - filter needs to be replaced - on order. Any ideas on diagnostics I can run to see what the problem is? Thanks
Old 06-26-2023, 10:23 PM
Oak Oak is online now
I had a similar issue on one of mine and it ended up being the little blue drive barrels were trashed on one end of the shaft.
What oil and filter are you using?
Old 06-27-2023, 10:23 AM
ironman's Avatar
ironman ironman is offline
If ya need the barrels, they're on eBay.
Kinda pricey, in my opinion, but what can you do,
they've got you over a barrel.
https://www.ebay.com/itm/363274652123
