Old 09-21-2014, 03:40 PM
IHinIN IHinIN is offline
Default Ag-Krane
I've been thinking of building some sleeve hitch mounted forks and came across this. It would be able to lift much higher than a set of sleeve hitch mounted forks that I was originally planning to build. I already have rear hydraulic ports on my 100. I plan on building mine with a lift height of 4-5ft.
Old 09-21-2014, 06:57 PM
bolivier's Avatar
bolivier bolivier is offline
I think it's an awesome idea. But I wonder about mounting it to the sleeve hitch adapter. I see it bending because of the long lever. What about mounting it like the IH attachments attach? They don't use the sleeve hitch adapter and mount directly to the U bracket on the bottom of the rear end. Just a thought.
Old 09-21-2014, 07:06 PM
I assumed (and hoped!! ) that the attachment would not be sleeve connected when I first saw the post,,,,,
Old 09-21-2014, 09:04 PM
I plan on mounting it directly to the lower 3-point bracket but plan on using the rear lift to make the whole thing tilt instead of adding a tilt cylinder like the one in the pic. I'm sure I'll need to add some front weight to the tractor. I'll do a mock up first out of wood to figure out all of the geometry.
Old 09-21-2014, 09:13 PM
bolivier's Avatar
Looking forward to your progress. I'm sure it will be awesome as are all of your other projects. I think it will be a very handy attachment when finished.
Old 09-23-2014, 10:18 PM
I did a quick mock-up to figure out the geometry and pivot points. It will take at least a 12" stroke cylinder to get 48" of lift. It sticks out about 48" past the back of the tractor when lifted so it will have a lot of leverage and take quite a bit of front weight to hold the front end down. Ag-Krane makes wheels to go on the bottom of their cranes to help on small tractors. I've thought of adding heavy casters to act as wheelie bars.
Old 09-24-2014, 11:44 AM
Calvins66Cub's Avatar
Nice work on the mock-up!
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 09-24-2014, 11:49 AM
chris hall's Avatar
chris hall chris hall is offline
can't wait to see this one !!!!!!
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 09-24-2014, 02:34 PM
Just tossing this out for thought, I've seen engine hoist's mounted on 3 point hitch's before. May be worth thinking about if you have one. Here is a link to one done by one of our members.
http://www.onlycubcadets.net/forum/s...ad.php?t=28822
Old 09-24-2014, 06:58 PM
Sam,
I've seen that done before. I want mine to have self-leveling forks as well as a hitch point for hooking a lift chain/strap to. Besides, I don't have any engine hoists laying around.
