Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 01-28-2017, 07:15 AM
Firephight Firephight is offline
Default Stens vs Kohler valves
How do the stens replacement valves compare to the new kohler (not nos) valves. engine is a k241 4000 rpm pulling engine
Old 01-28-2017, 08:38 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
OK................
Old 01-28-2017, 10:48 AM
If the valves are made by Kohler, they are the correct valves. What does them not being NOS have anything to do with anything???
Stens valves are fine.
4000 RPM motor huh..... You buying a flywheel?? Or are you going to take your chances on the cast one exploding between your legs?
Old 01-28-2017, 03:27 PM
Unless your original valves are burnt or bent, just do a valve job on them and you will be fine.
If you have to replace them, Stens are fine.
I assume you wll be running a gov., so stock flywheel will be fine at 4000 rpm. You do need a way to check that though.
If you are building your first puller, I promise you, stock motor will be fine. Mill the head .040 or .050 for some compression. tune the carb, set the timing and your good to go.
You won't know if the other pullers are following the rules till you have pulled awhile.
The key to winning in stock is tires, weight, gears and reading the track.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
