Electrolysis question
After reading these posts on electrolysis I made a plastic garbage can into my tank and it works good. My question is can cast iron parts be done in this manner.
NIK.
It dont cut grass, but its yellow. |
Hey Paul,
I did about half a dozen cast iron pieces last year with great success. Last winter I used it through the winter and just got some ice crystals. I believe using it creates a little heat. I had a huge chunk of ice this year when I went to use it. I've had a pile of parts disassembled and ready to run through it for over a month now waiting for it to melt.
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights 72, Serial #231093, K161S Serial #C281773, 36" deck 149 & Original Yard art 1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch 1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted 123 FEL and weight box 10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller |
Freezing was a concern with me too that is why I waited till now to build and test.
I may try something like this for the tank to soak stuff in. Figure it's long enough to do a frame.
http://www.tractorsupply.com/en/stor...-feeder-5-ft-l
If the part that holds the water is a plastic or vinyl then yes it would work. All you would have to do is insert some sacraficial metal into the sides, hook them together with wiring and you would be good to go. I have done only one part so far but it was pretty well painted and nearly all the paint came off and all the rust was gone. Tomorrow I am doing the foot rests. This is fun not having to scrape and sand and wire wheel all day. The part comes out looking kinda bad but when I washed it everything just came off. We are thinking of making a wood frame and line it with vinyl and use that for the frame, fenders, tower etc.
I built a large tank, It wont fit a super frame but nf and wf no problem. I framed it out of 2x4's and used a pond liner I found at lowes for about $40 got less than $50 in the whole thing. You have to be extremely careful setting the parts in, frame& rearend as they will easily rip the liner..
126 in surgery with weights, spring assist, 3 point and sleeve hitch 100 with woods finish mower and rear lift, Nice 125 with super nice sweepster, 1782 Super Diesel, 1650,782D in surgery, 102 parts tractor.. 3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment. |
so far I am impressed by the job that electrolysis does cleaning up things. Best thing is you just place the part carefully into the tank and get it going. The water gets real nasty looking but all you have to do is wait or do something else while your part is being cleaned. You do have to have enough time for cleaning, i.e. scrubbing and drying and priming the part as it will get surface rust real quick. You cannot let a cleaned part overnight without priming it. Eric and I are brainstorming building a wood frame long enough and deep enough to do the 102 frame all at once. We are thinking of putting the anode (sacrificial metal down the middle of the tank and supporting the frame on wood like squares of 2x4 so it does not touch the anode. Right now it has to wait a bit as the weather here is just too cold we had mid 20s last night.
Regarding bare metal, try protecting it with something like Krud Kutter Must for Rust. It is a phosphoric acid based product that converts rust and provides some protection for bare metal as well. I used it years ago on a Scout II body tub that a previous owner had stripped and then left in the weather. After sand blasting I used the "Must" to get the rust in any pits not reached by sand blasting - I sprayed the whole thing. Never had any problems with paint adherence or rust forming under the paint. It may be worth a try, of course it is a whole lot drier here where I live.
