Old 10-28-2020, 05:11 PM
RLause's Avatar
RLause RLause is offline
Default Check valve clearance
I purchased a Cub 1250 that had sat outside for several years. After cleaning out the mice nests and the wasp nests that had the carb throat plugged due to lack of an air filter I cleaned up the carb thoroughly. After all the electrical connections were cleaned the engine started but ran like crap. I've been working on engines for 70 years, but never saw one like this. Engine would not idle at all, at around 2500 rpm it would run but after it ran for several minutes it would slow down and die. Next the head came off and sure enough the gasket had been leaking. Sanded the head down, new gasket and it should run great, no way. Removed the cover for the valve tappets and the exhaust valve had negative clearance. I set the exhaust to specs and checked the intake, right on. Wrapped everything up and hit the starter, wow, it ran great and I called it a day. I don't know how far the valve was being held open but it was too much. I should have counted the number of flats that I turned it in but didn't.
Richard
Old 10-28-2020, 05:29 PM
Inactive Member
Sounds good.
