Old 06-26-2011, 07:33 PM
kutter kutter is offline
Default Cub Cadet 2166 PTO
Good day everyone, I have used the forum in the past finding fixes for my 2166, but I have run into an issue that I have not found an answer for yet. I blew a main fuse this afternoon. I chased the issue down to the PTO clutch. In doing some troubleshooting I found that across the coils on the PTO I am pulling 5 ohms of resistance not the 3.5 or so I should have. I am thinking that the clutch is bad, not a happy thought given the price. Is there any hope for it, can it be rebuilt or do I need to pony up the $300 for a new one.
Old 06-26-2011, 07:58 PM
5 ohms is fine, and would result in less current draw than 3.5 ohms, so that isn't the problem. You likely have a shorted wire somewhere in the PTO circuit.
Old 06-26-2011, 08:11 PM
I suspect that you may be correct, but since I have not purchased a manual for this tractor yet, I have always seemed to be able to fix it without one, I do not have a wiring diagram for it. I guess I am going to have to order a manual for it and see if I can trace out what is going on.
I hate electrical issues, I would rather tear down my Kubota rear end again than chase shorts.
Old 06-26-2011, 09:26 PM
Well I just discovered something that may be interesting. I have constant voltage supplied to the PTO, it does not matter what position the switch is in on or off, voltage stays at 12.55 volts. Anyone know if this is normal? I confess that electrical issues confound me but I would have thought that I should only have voltage with the PTO switch engaged. All that load of starting and the PTO trying to engage at the same time may be blowing the fuse. Maybe I have a bad switch?
Old 06-30-2011, 10:10 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Volts
The pto most likely should have 12 volts to both wires of the pto. When you pull the switch on it grounds one of the wires on the pto then it turns on.
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
