GT 2186 Stalling when PTO engaged
Last week, I hit a small hole in my yard, and I broke off a castor wheel and ran over it with my mower deck. Today when I was mowing, I ran over a small amount of tall thistle and my mower stopped completely. I restarted it without an issue but when I re-engaged the PTO switch, I heard loud noises and the mower stalls. It is like the engine can't get the deck moving and it stalls out. I cleaned out the grass/leaves on top of the mower deck but the PTO turns on but can't get the blades moving.
I'd appreciate any help you can provide. |
Check under the deck ( engine/mower off) probably something around blades or spindles. Also you should be able to move the blades by hand (again engine/mower off) with some amount of pressure. When mowing anything tall (over knee high ?) I move up to it and stop, then move forward some more until done.
You might have bent a baffle under the deck, causing it to hit the blades
