Greg Rozar AKA- CubDieselFan
Old 04-24-2022, 08:36 PM
129Richard 129Richard is offline
Default still confused
I have an oem switch part# IH-60736-C3 installed which i believe is the correct part? Also as best I can tell all is wired correctly.
Now i am back to the issue of when i turn the key to the start position the starter/gen turns as it should and then when I let key back to the run position the starter/gen still runs constantly.....Any thoughts?
Also found that the carb now leaks fuel....likely stuck float or bad bowl gasket...should be an easy fix!
Old 04-24-2022, 09:03 PM
The Ignition Switch is correct for the 129. (A) The Ignition Switch is defective, (B) not wired correctly, or (C) a wiring harness issue (shorted wires).
Roland Bedell
Buy: Made in the USA
Old 04-24-2022, 10:01 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Fair chance your starter constantly turning engine over without running is leading you to believe you have a fuel leak from carburetor.....in other words, flooding!
Plow blade
#2 Cart
QA36 snowthower
Old 05-06-2022, 10:35 PM
Default Still frustrated
Checked over wiring as best as possible without tearing things completely apart....all looks good. Checked all 4 wires on voltage regulator all are connected to correct terminals. Would a bad ground somewhere cause the starter to run continuously in the run position? Otherwise I'm out of ideas....I have an oem voltage regulator from my spare 129 which ran fine before I borrowed it.
Old 05-07-2022, 07:04 AM
The wire harness for the 129 should have a 3 pin connector for the ignition switch so there SHOULD be no way to connect it improperly.
Old 05-09-2022, 09:46 PM
Default Clarification
Clarifcation i have an oem v/r installed and wired correctly. Would an incorrectly wired starter generator cause it to turn continuously with the ignition in the run position?
Old 05-09-2022, 10:51 PM
Tim.E's Avatar
Tim.E Tim.E is offline
129Richard,,,,What do you mean EXACTLY when you say " when I turn the key to the run position,the starter/generator runs constantly" ?.
Is the engine running when you return the key to the "run" position?
Of course the starter/generator is still turning whenever the engine is running,because it is turned by the belt so it can "generate".
It is not like a starter on a car or a lawnmower that stops turning when you turn the key to the "run" position. It turns all the time when the engine is running to "generate". That is why it is called a starter/generator.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 05-09-2022, 11:00 PM
Tim.E's Avatar
I bought a new (wrong) voltage regulator once that caused the starter to run as soon as I hooked up the battery (with key in the off position IIRC). Turns out it was for a International Farmall 100 tractor (which DOES NOT use a starter/generator) and not an International Harvester Cub Cadet 100 garden tractor.
picture borrowed from tractordata.com
Old 05-10-2022, 10:16 PM
The engine just turns over with the switch in run position after trying to start. When I did get it started as soon as I returned the switch to run position the engine shuts off? Hope this makes sense.
Old 05-11-2022, 06:39 AM
It's a wiring issue
Only hot wire in the run position should be to the coil.
Think about it.
Time to break out some test equipment.
