Old 08-06-2017, 11:05 PM
MI Cub MI Cub is offline
Default Rear bucket
I've been working on this in the shop for the last week as I have time. Got it together and testing it out some. Planning on using it to mulch flower beds, haul the occasional load of dirt and stone, chain saws, gas cans. Pretty much a carry all. It mounts to the sleeve hitch.
I have yet to blast and paint it.
Old 08-06-2017, 11:13 PM
john hall's Avatar
Looks good. Looks like it tilts in to "hold" the load, how about out for dumping?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 08-06-2017, 11:24 PM
Thank you John, yes it tilts to hold the load. Rake or shovel it out when you get to your destination. I was kicking around the idea of a dump, but that would put the bucket further away from the back of the tractor, effectively lessening the working load. As it sits, it will lift around 300#.
Matt
1650, 44A deck, front blade, QA42A snow thrower, 1A tiller, 10" brinly plow, brinly cultivator, home made rear bucket, home made sleeve hitch.
Old 08-06-2017, 11:31 PM
I think that's why trents R bucket has the provision made in The middle for the dump cylinder. Although it takes up some bucket space it seems to still work really well with scooping and being able to get filled even with it in there. I'm sure he will be along soon.
Great job it looks plenty stout and very handy.
Old 08-06-2017, 11:41 PM
yettrbomb yettrbomb is offline
Looks awesome. Nice work
Old 08-06-2017, 11:56 PM
Thank you Alvy, there were many pros and cons of the way I built this vs one that dumped that were discussed in the shop. In the end, the fact that it is intended for getting light material to places I can't get a loader tractor made this design a win for me. If I have a lot of material to move, I go get my next door neighbors 2440 JD with a loader and have at it. We trade equipment back and forth, so I get the benefits of having a big tractor without having to maintain one. I am curious about this hydraulic dump rear bucket though!
Matt
Old 08-06-2017, 11:58 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=40746
Read away!
Old 08-07-2017, 10:18 AM
A couple of pivots on the bottom and you can make it a trip bucket, like they used back when I was a little nipper.
---wouldn't take much
Old 08-07-2017, 12:55 PM
That would be the ideal approach! Thanks George, I knew there was a good reason that I hadn't welded that sleev hitch bracket out all the way!
I was looking at a trip bucket that the neighbor has, but his has additional frame work that adds 6-8" of length to the bucket, which would take a lot away from the lift capacity. It will lift about 300# now, 200 fairly easy.
Hinges on the bottom and a catch on top would maybe push it out another 1/2". That should barely be noticeable, but a huge improvement!
Matt
Old 08-07-2017, 06:40 PM
You can use a some pieces of 1/2" pipe and rod or bolts for the hinges.
Nothing fancy but it will work well and be strong.
A spear/ notched on top for the rope trip will make you a nice setup.
