Cyclops hybrid
I have an 1864 with most of the plastic destroyed. I have an 1810 with excellent sheet metal/paint.
Will the dash tower, hood, side panels and grille fit the Cyclops frame? I'd use the Cyclops rear fenders and gas tank? |
Yes they will fit.
Edit: you will need to convert the steering from the tilt on the Cyclops to fixed. BTDT Woodward steering makes a coupling that will fit the shaft on the box and allow you to use the upper shaft form the Cyclops then all you need is some tube from a muffler shop to make a column. Woodward part # is C109 DD coupler this is what it looks like. The shaft on the left side gets welded to the coupler.
