Old 07-11-2024, 09:54 PM
ChubbyCubby01 ChubbyCubby01 is offline
Angry RZT 50 idle issues
I have a cub cadet RZT 50 that I am having engine issues with. The model number is 17WF2ACP010 and the serial number is 1L090h10248
When I first start the mower it idles really high for a few seconds and then calms down. When I engage the blades it idles really high again and then calms down. After that it cuts somewhat normal but any load on the mower (as in cutting somewhat high grass) makes it idle up or sometimes down.
I have recently changed the air filter, plugs, and fuel filter with no change. I also reset the governor with no effect.
I am not sure if the carb needs cleaned and I also saw something about an internal governor but I can't find an info or videos about that.
Any help is greatly appreciated.
Old 07-11-2024, 11:03 PM
Don't know what engine you are working on but the Gov. would be
internal. Adjusted but the linkage/shaft on the outside of the engine.
Wondering if there are adjustments for the sensitivity of the Gov.
What engine is it? Do you have a manual for it? It should describe those
settings for you.
Ken
Old 07-12-2024, 11:46 PM
It's a Kohler motor. I'm not sure of the exact specifics of the engine. I did "reset" the governor per Kohler but it didn't fix the problem.
