149 PTO brake
Hey guys, anybody ever replaced the brake material on the front PTO brake? Mine's shot, and I don't want to spend $100 on a new one. Was thinking about ordering some more of the brake material that I used on brake pads from McMaster Carr. Any ideas/comments?
How are you planning on cutting it out to the proper shape? It's a fairly snug fit once the "fingers" are engaged in the pulley basket, so it would have to be cut out precisely.
May not be the best item to economize on. |
I think he talking about the brake, not the clutch disk. If it worked on the service brakes I don’t see why it wouldn’t work on the PTO brake.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
Yeah, maybe I used the wrong terminology. Just the surface on the shoe itself.
Whoops sorry! I was working off my limited knowledge of only owning a 147. Forgot they introduced the brake system on later models.
Carry on! |
I say give it a shot, However, The PTO spins a lot faster than a brake rotor. Im not sure its the same type of friction material. Also, I would look into a different adhesive. Dont want a chunk of friction material flying off...
Was just working on one on a 129 the other day. It stops it pretty fast. As you’re applying the braking force you are disengaging the driving force simultaneously.
I don't think the friction material spins ......... It just sits there until when the PTO is disengaged and the friction material presses against the spinning PTO.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I'd be interested to know what material you order for the pto brake disc and what kind of adhesive you use. Thanks.
I say give it a shot, However, The PTO spins a lot faster than a brake rotor. Im not sure its the same type of friction material. Also, I would look into a different adhesive. Dont want a chunk of friction material flying off. I thought that was what I said.. To clarify.. I was saying when the material on the brake "which is stationary" comes in contact with the spinning PTO. I would want it to be the correct material and adhesive to ensure it wont detach itself from the brake due to the speed and friction of the PTO. Ideally I would think the implements belt that is being driven would do a lot of the stopping of the PTO just like it does on units without brake. That is assuming everything is perfectly adjusted and so on.
