Old 08-14-2014, 12:04 AM
EarlJ's Avatar
EarlJ EarlJ is offline
Default K-301 governor
I finally got around to putting together my 301 from the 126, I've had the parts and machine work done for nearly a year. I get it all together and some how I broke the tab off the governor shaft. Is there any way possible to remove and replace it without tearing everything back out?
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 08-14-2014, 12:26 AM
Looks like it has to come back apart.Sorry for the bad news.
was it new or used?
Up to 530 and counting...
Old 08-14-2014, 07:29 PM
austin8214's Avatar
It has to come back apart. Breaking the tab on the shaft is a symptom of turning the shaft the wrong way during the initial adjustment.
Old 08-14-2014, 08:26 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I explained this one once before. its a pain in the back side but with a set of mechanical fingers, a magnet , a light and a ton of patience it can be done with just taking the pan off. done it twice. don't ask for any tips or advice. its a real pain but it does save taking it all apart. 2-3 hours doing the first one. but it did save cost of a rebuild which is what would have had to have been done if I took the piston out.
