Old 04-09-2009, 12:16 AM
diesel_nut diesel_nut is offline
Default Adjusting reverse lever throw on 2000 Series
Should say: 2500 Series....sorry.
If you don't have enough throw in the reverse lever here is your fix. Very easy fix. See pics below.
Pic #1 shows the adjustment hold bolts. They are located directly under the floorboard under reverse lever. Loosen both bolts with a 3/8" socket. Reverse lever can now easily be pushed upward. Set at roughly 2-3/4 inches above metal on floorboard(measured from floorboard to top of lever). Any higher and the reverse lever rod will hit the bottom of the floorboard(Pic #2) when the forward pedal is depressed. Re-tighten bolts.
You can adjust height of reverse lever to where you get roughly full throw out of both forward and reverse levers.
If you want more you can(if you wish) bend the floorboard upward and/or grind a notch in reverse lever rod. Of course you risk paint cracks on floorboard and subsequent rust. Notching lever rod might be better because you can then paint over the rod.
Easy fix.
Note: Before adjustment my reverse lever was only 2" above floorboard.
Pic #1: (After adjustment. You can see where they were originally)
Pic #2: Reverse lever rod hitting floorboard with forward pedal fully depressed
Old 04-09-2009, 11:42 AM
Great work diesel_nut! Thanks for the pics.
Old 04-09-2009, 01:46 PM
Got to try it out today and the reverse pedal is sooooooooooooooo much easier to use now. Actually I left mine at 3" up.
1872 (SOLD) will live to regret it
GT2554
