Old 03-30-2009, 07:41 PM
rfrank's Avatar
rfrank rfrank is offline
Default BELT length?
OK. Ive got a 149 serial 20500447 U487758 I'm trying to get a belt to go to a QA42 inch deck, serial number 421 U 1113. I tried a 1/2 77 from CC but it appears its way too short. The belt fits nicely in both the PTO and the deck pulley as far as width. Suggestions for length 1/2 x 85? thanks for your help.
Old 03-30-2009, 08:34 PM
MBounds's Avatar
MBounds MBounds is offline
That 77" belt is likely an IH-477599-R2 belt and is indeed for the 42" deck spindles!! not the PTO to deck!!
If you don't need the spindle belt (you will sooner or later) return it to the dealer and request a PTO Belt...The Cub Cadet Belt/Blade Reference Guide says that a 149 using a older model 42" deck should use an 80" IH-490489-R2 belt.
Note, however, the 149 did not come with a 42" deck. You normally should have a 38" 44" or 50 ". Please check the cutting width of your deck. Provide us with the serial number of your 149 and the info on the deck data tag (found on the top left rear of the deck). Then, perhaps, we can narrow down the exact belts you need.
Myron B
Old 03-30-2009, 09:23 PM
rfrank's Avatar
Serial numbers are provided in the original post. thanks for the info.
Old 03-30-2009, 09:36 PM
MBounds's Avatar
You are correct ( a case of CRS! (:-}>...) The deck data plate information you posted clearly shows you have a 42 " deck (the first two digits) . Use the number I provided for the 80" belt.
Please look at your tractor serial number again: a 2050044U is a 109. A 2050047U is a 149. I'm assuming you hit the 4 twice instead of once.
Myron B
Old 03-31-2009, 07:11 AM
rfrank's Avatar
That number calls for a 3/8 x 80 pto belt. will that be an issue as far as width? The 1/2 in fit the pto pulley well. Is going down 1/8 in width going to cause issues? I can also go with a A80(1/2x80) belt and it should do the same?. Thanks for th info. It most definately is a 149
Old 03-31-2009, 07:22 AM
Inactive Member
rfrank:
If you are going the aftermarket route on the belt, here is a belt that will work. You will need in a Section A belt series.......A78
Old 03-31-2009, 10:29 AM
MBounds's Avatar
RFrank:
Please be advised that while automotove belts will work for a while (you will get tired of buying them), they are not designed for and do not stand up well for use as a PTO belt. Lawn & Garden belts are best for your purposes.
The belt numbers from the Cub Cadet Manual are what IH/CCC says are supposed to be used in given applications. It is your tractor and you can put any belt on there you want, but using the proper belt (width and length) provides the best results.
Myron B
Old 04-01-2009, 06:28 AM
rfrank's Avatar
I agree 100%. Im using the correct cub cadet belt or IH belt for the deck and pulley. BTDT. In a pinch an auto belt might get you thru the mowing of that day but not likely the season.
Thanks for all the good info.
Old 04-01-2009, 06:41 PM
rfrank's Avatar
Tried the IH-490489-R2 belt and its too short,forced it on and it pulled the idler so far back it was rubbing on the front axle. So after looking a little harder on the internet it looks as though it might take an 85in belt as the serial number is so low for that deck. Well keep trying and let you know. Im gonna order the IH belt tomorrow.
Old 04-02-2009, 06:59 AM
Inactive Member
rfrank:
How about posting a picture(s) of your tractor and deck. This would give us a better understanding of the situation.
